Fuel Pumps
    Fuel Pumps
    I have searched for a solid answer on this with no luck. I am running an h23 w/ garrett T3 and 450 cc's on about 7 lbs along with other shit, and i haven't seen any definitive answer to weather or not i need to be running a 255lph fuel pump or if stock will suffice. I have a fuel pressure regulator and pressure gauge so i should be able to maintain stock fuel pressure even with the bigger injectors, but if my fuel pump starts to crap out during boost, i run lean and melt my internals. Personal experience or actual knowledge would be much appreciated.
    stock fuel pump will easily hold 300 hp depending on what your plans are in the future will make up your mind if you would get a 255
    GOT BOOST???
    massive part out on accord almost everything is going
    http://www.cb7tuner.com/vbb/showthread.php?t=125294
      how old is the pump your running now. if it old, i'd say spring for a 255 just to be safe.
        I would definetely upgrade your fuel pump...they arent too expensive
        SOLD!!
        Boosted H22
        375whp 298 ft/lbs at 15psi
          100 bucks for a 255 is cheap insurance
          instagram @mikeymeyagi
            for certain, the stock pump may be sufficient, but why risk it? I got mine for about 80 bucks from www.injectedperformance.com
