Pulleys.....?
    Pulleys.....?
    DO under drive and oversized pulles really make that big a difference? what effect does it have on the alternator's charging the electrical system? and is it worth it?
    Aem makes pulleys
    obx makes a crank pulley
    whats the deal?
    thanx
    peaceout!-jl
    Sold my car. But at least I bought another Honda(Acura)!
    thanks..it helped a lot..i think im gonna buy an underdrive pulley
    peaceout!-jl
      Crank pullies post pretty good gains, but it is up to you to decide whether or not they are worth it. The way the stock Honda pulley is designed it dampens the vibrations from the engine, etc. and when you take this off it will take away from the life of your engine. This is effect is more noticeable with higher power/rpm's but either way in the end it will take away from your engine's life. Plenty of people have ran them for years and have had no problems but most of them are not running extreme set ups either. The other pulleys will work fine as long as you aren't running some crazy stereo set up or anything like that.
        hmmm
        thats a good point but people say it has no effect and others say it does.....? i have an optima battery does that help at all?
        thanks
        peaceout!-jl
          Re: hmmm
          thanks
          The battery is only used when the engine is not running, and mostly only for starting the engine.
          Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
