P2R Thermal Intake Manifold Gaskets
    is it worth the trouble of installing one of these when you only have the usuall bolt-ons i/h/e?
    http://www.powerrevracing.com/gaskets.html
    ive heard of people using them on turbo setups or on built engines. but i dont kno if it would benifit those with just the usual bolt-ons though.
    My cb7
    h22a
    5-spd lsd
    Lord, grant me the serenity
    to accept the things I cannot change,
    the courage to change the things I can,
    and the wisdom to hide the bodies
    of those people I had to kill because they pissed me off.
      will you feel a difference? no
      will it make a difference? probably
      is it worth installing? depends on your mechanical skill...if you've pulled multiple motors in your lifetime then installing a IM gasket is cake. If you've never done an install like this than it may not be worth doing.
      1990 Frost White EX Coupe F23A1 - PART OUT
      01 DC4
        Another thing to note is the fact that those are reuseable, which is a plus. I myself would support Bisimoto instead of this company or Hondata.
          hummm..
          though i have the basic skills for this job.. based on your 1st two answers, i guess there's no point in doing this..
          i would too.. but i got a good deal on it.. also, it's for the G..
            ^Yeah, don't get me wrong, it looks like a really nice piece! Bisi's gasket is nice too, fit perfect on my F22A. Hondata will always get a major from me b/c of the F22B1 screw up they made years ago. They made a legit F22B1 gasket and labeled it as F22/H23, they corrected the problem but I did have an "F22/H23" labeled gasket and sold it to a member on here w/ a B1.
              I have used this brand on a couple cars with no issues. If you are pulling the intake to do something other than just the gasket then I say go for it.
                its a pain in the ass to scrape off the old paper gasket, i have a hondata intake manfiold gasket with bolt ons... i cant really tell you if i noticed a difference or not because i did a swap all at once
                  i just sold my Bisi IM gasket, but i swapped it on the same time i installed an h23 IM. together they made a big difference on the butt-dyno, but idk about actual power numbers.
                  i agree with the above posts about supporting bisi over anyone else.
                    if i remember right, bisi said that had tested a 7 hp gain on a f22 with his gasket.
                    spin city
                      Yes. These phneolic gaskets are perhaps one of the best, cheapest mods you can do to your car.
                        why so?
                        got the gaskets packaged with a plenum spacer for the price of the spacer.. so, i'm just might sell the gaskets($35 on ebay) if it isn't worth it..
                          They cool your IAT's quite a bit. Cooler iat's, more power.
                            so they do make that much of a difference to gain atleast a few HP..
                            any personal experience, dyno results or data you may have for good reading regarding these gaskets?
                              All personal experience. I've never done any before and after dyno runs, but every single motor that has it feels much peppier. The datalogs definitely show the IAT's dropping by at least 10* and the most important part is that they STAY that cold at all times, even when sitting in traffic.
