So i bought an omnipower 70mm throttle body and i noticed the nipple where our map sensor connects to is not there. Instead i discovered that on this throttle body the map sensor sits on top of it. Now my question is if i were to get this aftermarket map sensor would i have to splice in a plug from say a b-series motor to the plug that connects our map sensor. and if so would this work perfectly fine? Im sure this is a little confusing. Thanks again for the help
