soo.. f22 long block plus p14 pistons?
    playing with ideas. thinking of taking a f22 to 87mm and tossing in a set. i build motor and will check it but from everything i know there shouldnt be issues.
    maybe fitting them on the rods but i didnt double check that yet. any pointers or reasons as to why it wont work. i searched around but for some reason i didnt see anything related, i, good with google fo sho and like i said, didnt see anything.
    Superior Tuning Solutions
    Dedspool MFG
    1995 Civic Coupe : A/M F swap
    LOCK.IT.UP
    you'er resleeving the block right
      Good luck getting the F22A to sonic test above 86mm.
        I will not be sleeving, im simply going to pop my head off and check it out, if i see that it is no thinner than a b20 im going to do it. i just havnt been into this motor yet and looked at that as far as an issue, this idea just popped up, im not a new builder, +2 vs 1.5mm is what i have to check boring wise to make sure there will be enough material.
        if not ill just use a f23
        heres my car BTW, just so you know, im not new...
        Dedspool MFG
        LOCK.IT.UP
          http://www.cb7tuner.com/vbb/showthread.php?t=152290
          guess someone did do it and it works fine, see ya with a new all motor setup soon.
          Dedspool MFG
          LOCK.IT.UP
            While I'm sure you might know a thing or two about engine builds allow me to raise a few points.
            First, that build isn't done to my knowledge. It certainly never finished in thread you referred us to and he's had the same message in his signature for a few months at least. Maybe longer. There wasn't even certainty as to whether or not it would work because of the thickness of iron remaining in the cylinder.
            Second, read the engine dimension sticky in the performance section and do a bit of math. I know you're wanting to go all motor but that piston is .5mm taller than the PT3 piston. That difference has been accomplished hundreds of times but it's something you still need to be aware of.
            Third, with the cost of machine work to accomplish this you may be better off with an F23A block using RSX-S pistons. I know that means an addition purchase but you're taking machining out of the equation and goin with a proven combo.
              the total height is taller. besides that claying the motor will be the only way to see if it works. it was simply an idea and ill throw a set in and see what i end up with. machine work price isnt a biggy, and as for a PROVEN performer, every OEM honda part is, im going based on measurements and the fact we know that they share similarities, if i radius the edge of the combustion chamber looking for bigger quench pads there shouldnt be an issue with clearance regardless of if it fits before claying. i realize there will be work involved. ill do it, thats fine.
              also, RS machine has the 12:1 b series 85mm pistons, that may be another route to go since i have a fellow f22 civic chassis guy that looked into it and is acually running the setup. if you look a b20 sleeve thickness vs a 87mm f22 block is actually better on the F series end.
              The idea is to retain the stroke and go bore for the gain in displaement, not the other way around compromising.
              Dedspool MFG
              LOCK.IT.UP
                yea im not done yet...no more accord means my project stopped.
                as for turbo, im not sure i would consider it because you're already stressing the factory sleeves. going bigger isn't going to help but hey if everything works, it'll give me more confidence for my setup!
                btw: my aftermarket 87mm pistons ended up being made for a press fit rod so no need to convert to a floating style wrist pin
                I <3 G60.
                  I actually wondered about such a setup last year. What compression did he yield on the b20 12:1 piston in his f22? I actually wanted to use these pistons for a turbo setup, a lower compression of course, but how long has he been running his setup? Is it daily driven?
