with all of the following combinations the piston will need to be turned 180º in the hole and when using the 87mm tsx pistons you will need a custom head gasket like the ones from bisimoto. i also recommend using new pistons if possible. they can be bought with ring sets for usually under $400. used pistons tend to be shaped to the engine they came from which if is excessive can cause premature ring failure in the engine you install them in. i have found that oem pistons are more than capable of the 230-250whp range naturally aspirated and due to their expansion rate are much less noisy and tend hold compression longer. this is due to minimal piston slap when the engine is cold compared to forged pistons. this all in mind, forged pistons are much stronger and when planning a higher HP goal you need to weigh your options.
this is a bone stock F23A bottom and bone stock F series sohc vtec or non vtec head.
this is a bone stock F23A bottom and milled F series sohc vtec or non vtec head( .020").
this is a F23A bottom bored to 87mm with 04-08 K24A2 TSX pistons and bone stock F series sohc vtec or non vtec head.
this is a F23A bottom bored to 87mm with 04-08 K24A2 TSX pistons and milled (.020") F series sohc vtec or non vtec head.
this is a F23A bottom bored to 87mm with 09 K24Z3 TSX pistons and bone stock F series sohc vtec or non vtec head.
this is a F23A bottom bored to 87mm with 09 K24Z3 TSX pistons and milled (.020") F series sohc vtec or non vtec head.
this is a bone stock F23A bottom with 02-04 RSX pistons and bone stock F series sohc vtec or non vtec head.
