Cam Question
    Cam Question
    Allright guys i am deciding on going N/A and i was thinking about going with some Delta 272 cams, now my real question is what do i need to install along with my cams? like Fuel system or what? Let me know guys, thanks. Also how much hp and tq gains will it give me? or how muhc has it givin you?.
    R.I.P. Landon Hilburn 06-27-08
    Soon to enter the family.
    CG Coupe!
    92 Accord EX Sedan (Newest project)
    Members ride thread 92 EX Sedan
    Members ride thread old 91 LX Coupe
    I would say get your throttle body bored:
    http://www.maxbore.com
    Also get an A6 intake manifold and a PT6 ecu (off an A6)
      Fuel system upgrades, igntion system upgrades, cam gear, chipped ecu or piggy back system for ECU tuning
        I like the throttle body.. I might do that first..
        CG Coupe!
          Like what all do i need in order to be able to install it all and go?..
          CG Coupe!
            What do you mean what do you need?
              I mean by fuel system, Ignition system, etc, etc.. What parts do i need/ upgrades?.
              CG Coupe!
                there is no reason for you to get a pt6 u nless u get an a6 manifold.
                ILBB
                People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
                Mk3 Supra Member #2
                Originally posted by DarkShadow707
                The world needs to be reset.
                  ILBB
                  Thats also why im asking what i need, lol.
                  CG Coupe!
                    you need to search more.
                    H.S.A.E.
                    90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
                    99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
                      In order to absolutely just get it up and running, you will need a new cam seal and a valve cover gasket. You would also be wise to change the Timing Belt, Balancer Belt and water pump while you are in there, unless they have been changed VERY recently. One thing that is good for a few extra HP is to remove the balancer belt altogether, and just leave the tensioner on there. you will have to put up with a little vibration, but it really isn't that noticeable.
                      If you want to squeeze a little bit of extra horsepower out of it after it is running, the next best things would be:
                      1) A throttle body (assuming you already have an intake)
                      2) A header or F22A4 exhaust manifold, if you don't already have one
                      3) An H23/JDM F22B or F22A6 Intake manifold and ECU
                      4) Something to enrichen the fuel mixture as necessary. (The above modifications should still be within the limits of the stock system, but could be pushing it, depending on how your fuel system is functioning.) Honda's generally run a little rich in the top end anyway, and the only real way to verify if you need to do this, or if your changes are helping, is with a dyno and a wideband O2 sensor. The "butt dyno" will not be effective here at all (is it ever).
                      From there, you can build a bottom end and bump up compression etc, but that is another topic entirely.
                        timing belt is Brand new (aprox 500 miles), i think i might Bore out my throttle body here in about two weeks..
                        CG Coupe!
