i would like to have comments and suggestions about my next summer set-up.I would like to make a least 200 whp.
h22a4 01 not sh
h22a4 01 manual tranny
type s pistons
chipped p28 ecu
skunk2 intake manifold
clutch ACT 4puck with springs
pressure plate prelude type s
flywheel fidanza 8lbs
fuel rail str
fuel pressure regulator
cam gears adj volution
but i hesitate on some points
I what to mill the head a little bit maybe 0.10mm Would it be not enought?
Should i put cams ? I was thinking type s cams.
I need obd1 injectors cause i have 290cc injectors
.Should i put 345cc or RC 370?
Do i need a header? I don't want to buy a rmf header.What alternative did i have?
feel very comfortable to tell what you think.
h22a4 01 not sh
type s pistons
chipped p28 ecu
fuel rail str
