N/A H23 project
    N/A H23 project
    I just need to know any issues I may have with the following build:
    -H23 block and head
    -Oversized Type S pistons (.25mm over) So I can start with fresh metal in the cyliders
    -Crower stage 1 cams
    -adjustable cam gears
    -port and polish
    With the slightly more aggressive cam, will there be any clearance issues with the high comp type s piston?
    The cylinders are FRM sleeves, Not metal.
      It depends on what year prelude you have to know if you have frm sleeves!
      99 GS300 (Aristo) 2JZ Power
      Bought from:gdout, bb6-sh
        Do some math.
        I doubt anyone's done this type of build before(with the exact parts) so no one can give you a solid answers, only theories.
          Get it clayed
          I know with the H22 head your setup would have about 12:1 compression. I'd go with regular 87mm H22 pistons
          Originally posted by lordoja
            Are you sure about that? From what I been hearing lately all the h23's have frm sleeves. They were only made from 92-95 anyways. The h22's have the open deck and closed deck story in the years. And the journal size issue with the one year
              all h series have frm sleeves, id be worried about over boring that much, I believe h23s have a 86mm bore and h22s 87mm, then if you want to get overbored h22 pistons im pretty sure you wouldnt have much sleeve left, i would go for stock sized h22 pistons.
              H22-T FTW!!!
