what is the highest comp i can have running pump gas
compression?
12.5:1 ish
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
Originally posted by MRXi've done 12.5:1 compression before. Works fine on 93. Tuned it in jacksonville too.
my boy's running 12.5:1 on his built teggy on 93oc no problem
My Ride thread
Flickr
13:1 starts pushing the boundary of retarding the timing too much to compensate for the increased cylinder pressure. You can run higher than 12.5 and just lower the timing to rediculous numbers but its counter productive seeing as you may also have to run rich a/f's to help compensate; VERY counterproductive.
I'm on the southside of townKnowledge is power...in EVERY sense of the word
Originally posted by MRX13:1 starts pushing the boundary of retarding the timing too much to compensate for the increased cylinder pressure. You can run higher than 12.5 and just lower the timing to rediculous numbers but its counter productive seeing as you may also have to run rich a/f's to help compensate; VERY counterproductive.
I've always been interested to see people running 100 or 104 octane Sunoco or other brand gas for a N/A application and what compression ratio they use. There's a ton of info for maximum CR on 93 octane but I haven't found much for 100 octane. Expensive, but still available at some local gas stations around here.Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
Originally posted by uslspctI've always been interested to see people running 100 or 104 octane Sunoco or other brand gas for a N/A application and what compression ratio they use. There's a ton of info for maximum CR on 93 octane but I haven't found much for 100 octane. Expensive, but still available at some local gas stations around here.
