16mm rear sway bar...
    Hey everyone, I was just wondring, since I have a Canadian Lx (US Dx), I'm pretty sure I have no rear sway bar. Now Ive read that the 2.3 cl rear sway bar would work on our cars and it is a 16mm solid, not hollow, bar. I looked around and found that this would be comparable to the aftermarket Intrax rear sway bar which is also a solid 16mm bar. So my question is, do you think I will notice any differences with this or do you think that I will only actually benefit from a rear sway bar if it is 20 or 22mm (such as Progress and ST.) Does anybody have the cl rear sway bar on their car or the intrax?Any help would be great. Thanks!
    1992 Honda Accord Coupe LX
    having one would deffinately be better than non for a daily..
    on the other hand, size is a matter of personal preference, purpose(autoX, track, circuit, etc.) of your set-up and installed parts to compliment the sway bar(urethane bushings, camber kit, camber settings, etc.) .. also, it should also compliment the front suspension set-up..
      wouldnt even waste my money or time. a progress rear sway will put you about neutral.
        Thanks for the input guys!
