would the rear brakes(all the components like the trailing arm and all) off of a '94-96 accord bolt up to our cb7 chassis? i seem to be able to find more CD5 accords in jy or being parted out than the CB7 EX or SE accords. i wanted to do a rear disc brake swap but i need to know before i go get the parts.
CD5 rear brake system
the main this i want is just the rear disc brakes. ill probably just use those instead of the entire suspension if its gonna be a problem of camber.Originally posted by JaK FRoSTWhiTE View PostYou can get everything. Rear subframe, trailing arms, LCA's.
The one thing is that you're going to have more negative camber in the rear.
Ask icedplaya, we are still trying to find out how to get rid of that.
Maybe using the CB stock LCA?
Dont know if the camber kit can adjust your rear camber that much.Originally posted by DRzCB72nr View Postso if camber is the problem, get a camber kit they are kind of cheap for the rear. You can always use washers also
Icedplaya is already running the washers in the rear. Still has alot of negative camber.
Maybe the CB LCA is the answer, who knows, we'll find out soon enough.
I never got a chance to put his car on the alignment rack to see what the numbers were.Originally posted by Shadow1 View Postyou think an aftermarket camber kit would help instead of using thousands of washer? lol
But i wouldnt do the thousand washer trick lol.
What are the adjustments on the aftermarket rear camber kit?
i dont know what the adjustments on the aftermarket kit is. id have to check and see. i havent even got a camber kit for my car now as low as it is. lol.Originally posted by JaK FRoSTWhiTE View PostI never got a chance to put his car on the alignment rack to see what the numbers were.
Knuckle, upper arm, and trailing arm are the same as the CB's.Originally posted by Accrdwgnguy View PostWould it not have all that extra camber if you just used the knuckles from the CD5?
The only thing different are both lower control arms and subframe.
So in theory, maybe using both CB lower control arm and subframe.
Thats what we're going to do with Icedplaya's set up to see if the camber changes.
