Question Is It Possible To Cut The Stock Springs To Drop My Cb And Wat Can I Use TO CUT IT
Diy Slamming
Yes it's possible, and there are multiple ways to cut springs. However, you're setting yourself up for a very uncomfortable ride and unsafe driving conditions.
http://www.cb7tuner.com/vbb/showthread.php?t=470
I heard that I can cut and melt my stock springs...is this a good way to save money and lower my car?
NO!! Since your stock springs arent highly pro rate, you will be cutting off your springrate as you go. You will have a very stiff, often uneven, harsh ride and you will blow your stock shocks. You also can never revert back and if you screw one thing up you are basically screwed alltogether. Its a money trap.
^ wut he said.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
