I Tried Doin A Search, And I Replaced A Few R/p But None On A Cb7, I Took Out All The Mounting Bolts And The P/s Lines On The Rack And Pinion And Nothings Holding On To It Except The Steering Knuckle...and I Tried To Wiggle It Out And Move It And Everythign And That Sucker Won't Come Out, I Can Spin It 360 Deg. And Stillwon't Come Out...is There Any Way I Can Take This Out..i Need It Asap Cause I Have So Much Play..thanx Alot..
Rack And Pinion
Originally posted by Haccord21 View PostKinda bad with looking at pictures. is there any bolt that you see that holds it? or is it just the rubber piece? if its just the rubber piece try prying it out, just make sure it wont brake anything.
found out that the bar that connects to the tie bar happens to give the rack and pinion a hard time to come off. how do i get it off with the metal bar for the tie bar being on the way?
