anybody know where i can get some airshocks??? you know the kind that you put air in and it gives you a stronger suspension????
Air shocks
didnt know they made some for the CB's.
Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
I'd be very suprised if you could find any to fit an Accord.
What they are intended to do is to raise rear ride back to the static height when a car is heavily laden, particularly when towing etc (vertical load on tow ball). They're not really intended to enhance handling in normal circumstances. If you want to improve handling then there are much better ways, i.e. ways that actually work...Regards from Oz,
John.
i think he's talking about the ones made for "track" use, if im not mistaken. forgot the brand who makes some but they make them for the "common" cars, which aint us.. i dont think "air shocks" is the correct term.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
so how would i go about doing thisOriginally posted by johnl View PostRear ride height could be increased by welding extensions onto the bottom of the rear coilovers. Just extend the 'legs' that attach the damper body to the LCA. Don't attempt this if you're not confident that you know what you're doing, don't weaken anything...
Can you weld / fabricate? You'd need to extend the length of the attachment 'prongs' at the bottom of the damper body so that you can drill new bolt holes that are further from the damper body.Originally posted by H22A91CB7 View Postso how would i go about doing this
The 'coilover' will be longer from suspension attachment to chassis attachment, thus increasing ride height in a somewhat similar manner to moving the lower spring seat higher on the damper body.Regards from Oz,
John.
air ride is fail!!!!!!!
...dont waste your money on this shit man
http://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
I agree, air ride will be expensive and is prone to failure. A nice set of coilovers will do much better in terms of reailibility and ride quality. My Subaru XT at one time had air ride and needed $1200 struts every year! We got sick of that and went with a aftermarket strut and never looked back. Blowing a o-ring on a corner can be deadly.
If you need better loading ability look into wagon struts & springs.
