why does ground control specify the type of strut that you are going to use? are there any physical differences?
ground control coilover differences?
I think it only matters if you use Koni struts. The threaded sleeves from ground control fit the koni struts exactly and seat on the little clip instead of the strut cup that is usually welded on other struts. The koni version is a perfect fitment and sometimes require sanding the paint to get the sleeve over while the other struts they are loose fits and require using rubber spacers.Originally posted by wed3k View Postwhy does ground control specify the type of strut that you are going to use? are there any physical differences?
Koni/GC
KYB AGX/GC
why didnt you tell me sooner?!?!?!! i can now buy them from a member, lol.Originally posted by Blk EX Coupe View PostNo problem at all.
Just so you guys know the non-koni version will still work with konis, but you will need to use the spring cup/seat. The koni version will only work on koni struts though.
actually they have a different sized ring that goes into the bottom of the sleeve so i slides tight around the strut to give it a little grip to the strut. atleast i think so, because you have to specify which strut you have when ordering, whether it be a koni, agx, bilstein, etc....
My Members Ride Thread
You have to think outside the box to get IN the box!
Im looking at them also but am trying to fdind out where you can get them with custom spring rates as some members on here talked about.
If anyone knows speak up!"you can catch me swoopin 4G coupin switchin lanes" haha haha.
1993 SE coupe drag car ahoy!
1992 EX coupe 5 spd **sold
Did work for: jhoff_cb7
you have to actually call them and ask them about getting the custom spring rates when you initially order them with the sleeves.Originally posted by JDMCB3Si View PostIm looking at them also but am trying to fdind out where you can get them with custom spring rates as some members on here talked about.
Weksos has Koni+Ground Control sleeves and lets you get custom spring rates
http://honda-tech.com/showthread.php?t=1689953
http://www.weaksauceparts.com/store/...roductid=18820Originally posted by weaksauce.orgweksos industries is having a sale on GROUND CONTROL (non-limited edition)
and KONI SPORT - SP3 - RACE combination packages. These GROUND CONTROLS are made SPECIFICALLY to fit the KONI shocks with a sized sleeve and clip. You ARE able to get them with CUSTOM SPRING RATES to your desire.
I would assume that if it's any KYB strut other than AGX's then you would use the ones labled as KYB. Calling/Emailing Ground Control would be the best option.
530-677-8600
9:00-5:00 PST
mark@ground-control.com
