does any1 know if acura vigor struts and springs are the same as or can be bolted into a cb7????thanks for the help
ACURA VIGOR struts and springs into a cb7?
why do you want Vigor struts and springs? Why don't you just get 90-97 Accord Strut and Spring....
Just because Vigor Rear Sway Bar fit on CB7 doesn't mean Strut will fit....
I'm pretty sure Spring Rate is different because Vigor is V6 and i'm pretty sure it is heavier than cb7
Just get the part that are engineer for the car.....for your safety sake....
Originally posted by XcluziveAZN View Postwhy do you want Vigor struts and springs? Why don't you just get 90-97 Accord Strut and Spring....
Actually, it is a 5 cylinder...RETIRED...
ENGINE AND ELECTRICAL
Engine Type= 2.5 liter, SOHC, 20-valve inline 5
Horsepower, SAE net= 176 hp @6300 rpm
Torque, SAE net= 170 lbs.-ft. (23.5 kg-m) @3900 rpm
Redline= 6800 rpm
Fuel Cutoff= 7100 rpm
Bore & Stroke= 3.35 in x 3.40 in (85.0 mm x 86.4 mm)
Displacement= 150 cu in (2451 cc)
Compression Ratio= 9.0:1
Induction System= Programmed Fuel Injection (POM-FI) with Dual-Stage Induction System
Valve Train= 4 valves per cylinder,screw-type clearance adjusters, single overhead camshaft,belt-driven
Engine Block= Aluminum alloy with cast-iron cylinder liners
Cylinder Head= Aluminum alloy
Emission Control= 3-way catalytic converter
Ignition System= Electronic ignition with dual knock sensor
Alternator= 13.5V,115 amp. max.
Battery=12V,72 amp./hr.,maintenance-free
BODY/ SUSPENSION/ CHASSIS
Body Type= All-steel unit body
Front Suspension= Independent double-wishbone with coil springsand stabilizer bar
Rear Suspension= Independent double-wishbone with trailing link, coil springs and stabilizer bar
Shock Absorbers= Front Hydraulic gas-pressurizedwith Honda ProgressiveValve(HPV) Rear: Hydraulic gas-pressurized
Stabilizers Bars= Tubular,
Front 1.07inch diameter x 0.16inch wall thickness (27.2mmx 4.5mm)
Rear: 0.63inch diameter x 0.10inch wall thickness (15.9mm x 2.6mm)
Steering Type= Rack-and-pinion, speed-sensitive, variable power-assisted
Steering Ratio= 17.3:1
Steering Wheel Turns, lock-to-lock= 3.5
Turning Circle, curb-to-curb= 36.2 ft (11.0 m)
Wheels Cast-aluminumalloy, 6.0 JJ x 15
Tires= 205/60 R15 91H M+S All Season Bridgestone or Yokohama
Braking System= Dual diagonal, power-assisted, 4-wheel disc brakes
Front Discs= Ventilated, 11.0 in (280 mm) diameter,
0.91 in (23 mm) rotor thickness
Rear Discs= 10.2 in (258 mm) diameter
0.39 in (10 mm) rotor thickness
Swept Area= Front: 229.2 sq in (1479 cm2)
Rear: 169.8 sq in (1096 cm2)
Parking Brake= Disc type, mechanically actuated on rear wheels
Anti-Lock Braking System= 3-channel Honda R&D-designed system with 4 wheel-speed sensors and electronid hydrauliccontrol unitMy ride History:
Accord 90 lx auto: Gone
Accord 91 dx MT: Gone
Accord 92 lx auto: Gone
1st to D.I.Y custom RED/CLEAR's
