im hearing a rattle from the front passenger side of the car whenever i go over a sudden bump. it does not rattle over smaller bumps, only the quick/sudden ones. i have checked for looseness/play and there is nothing...
BUT, the only thing i noticed was that the inboard brake pad has a good amount of play in it when i grabbed the wear "sensor" and wiggled it around. i would say a good 1-2mm of play between the caliper piston and the rear of the pad.
which brings me to this. i then checked the driver's side inboard pad for the same play, and i get nothing, it touches the piston and i cant move it.
i raised both wheels off the ground and popped the tranny (automatic) in neutral. now i know both wheels should begin to spin even in neutral, but i was only getting rotation in the passenger wheel (pretty fast if you ask me), and hardly anything in the drivers wheel. then i had my father hold the brake pedal down and both sides lock up nice and tight. then he puts it in D and both wheels spin freely.
the brake pads i have on are also not even 2 months old. they are Wagner Thermo-Quiets (no shims required). both calipers are also fairly new.
does this sound like i have 2 different issues, or maybe the rattle is from the free-play of the brake pad? if that is the case, why would there be so much play between the caliper piston and the pad?
