tas pro uca ball joint type?
    Hey, can anyone tell me what ball joints come in the Tas pro uca's
    I have tried to contact them, but they are closed until the 29th of January for maintenance and other stuff.
    I am thinking they are Spc, but am not sure.
    So if anyone knows please let me know.
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
    ingalls.
    MadLab Racing
    Southern Maryland
      hmm
      Does that mean they have the huge nut on top?
      Next question is do you think the Spc would fit in them? I am hoping they are all the same size.
        yes they do have the huge nut on top.
        I have heard that all are interchangeable.
        but have not done so myself.
        MadLab Racing
        Southern Maryland
          Thanks for the information I will let you know if they fit.
            I would never buy them again.
            cost way to much money.
            since the skunk2 ef ones work, that is my new route.
            MadLab Racing
            Southern Maryland
              On the web site it states them for 184 for front and back which is not all that bad. Spc for the for would run that much and you don't need a press. Just to install them. Cause someone confirm that these are ingals front and back because I just might buy them because I have terribly toe and my tired eat so fast. Pls let me know
                link to the taspro upper balljoints
                these are what I was referring to.
                not really sure which ones you are talking for front and back,
                not sure what your referring to. I can't see it. post a link.
                MadLab Racing
                Southern Maryland
                  i wouldnt buy skunk2 ef ones, they arent long enough. they fit but they will give u more camber then you would like.
                    more camber in which direction?
                    I am using the accord v6 front 5 lug knuckles with them.
                    and djcaz_aom uses them, his camber is not bad at all, right where I like it.
                    he also told me that he does not have the pro version, and that if I got the pro version
                    that would put the camber right where I am looking.
                    I think with the 5 lug at -1.0 is perfect. so that is for my setup.
                    where they reside on the 4 lug setup I am not sure.
                    MadLab Racing
                    Southern Maryland
                      the ef skunk2 uca's will give you major neg camber. im running them and i have them pushed out max and im at -2.8 degrees. (im on 5 lug prelude fronts, lowered on ff2's)
                        which ones are you using?
                        MadLab Racing
                        Southern Maryland
                          shoot, its been awhile. i want to say the pro. ill have to check tomorrow. i still have the box, but its at work.
                            just checked, im using the pro series
