is the front driver-side axle nut reverse threaded or is it regular? i can't get it lose and just want to make sure im going the right direction...
axle nut
That's the only way I've taken them off. Actually I use a 1/2" ratchet instead of a breaker bar to keep it from swiveling. Done it many times. And never broken a Craftsman rather doing it either!Originally posted by Straight Success View PostOnce in a blue, people get lucky with a breaker bar and steel pipe.
You better put some steak, fish, eggs, and a shit load of pasta and potatoes in your diet.Originally posted by Tippey764 View Post...
On the left side i used a 3 foot breaker bar and stood on it. I only weigh 105 but it still worked luckily.
Just sayin'!The Lord watches over me!
- D. Chappelle
The axle nut is definitely regular. All I've ever used is my craftsman breaker bar. I've broken it once and it was on the swivel part you put the socket on. If you're really having trouble double check the spot that gets indented in to prevent the nut from working itself out. If you're taking the nut off by hand it's important. If you're using a nice impact that indent makes no difference.
http://www.craftsman.com/shc/s/p_101...3&blockType=L3
lol i just can't gain weight. It doesn't matter what i eat i just can't gain weight. I eat fast food probably every day and don't put on any weight.Originally posted by Straight Success View PostYou better put some steak, fish, eggs, and a shit load of pasta and potatoes in your diet.
Just sayin'!
I bought my car from the original owner and she always had the car serviced at a Honda dealer. The first time I tried taking the nuts off, the driver side nut snapped two craftsman breaker bars and one no-namer breaker bar (probably because I had an 8' metal square pipe attached to the end trying to break the nut loose.
Since I was putting new brakes on while the nut was off, I ended up drenching it several times for two days with WD40, so it would soak in. Seemed to break loose after sitting for a couple days."There is nothing wrong with you that an expensive operation cannot prolong."
if you are not using an impact gun give the nut and axle end a couple whacks with a hammer, the vibration can help break the corrosion.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
Broke two 1/2" Craftsman breaker bars with a 4 foot pipe. So stepped up to 3/4" breaker bar from habor freight with a 4' pipe. Also used the car jack trick on the breaker bar head.
I weigh 260lbs and it took big 3 bounces with all my weight before it broke loose. The right side was fortunately a lot easier.
