17x9's & 235/40's.. Offset Question!
    So i plan to squeeze 17x9's under my CB7 in an attempt to put power to the ground.
    And i have a set of brand new Falken RT615's in 235/40/R17 ready to be used.
    As far as ride height goes.. I have a 1" wheel gap F+R and i'm not changing the height for nobody.
    From reading around on this forum i know that 17x9 is a very big wheel for a CB7.. But it's easily possible to fit!
    And rolling/pumping/pulling/flaring/etc the guards is a must and i will take care of that too.
    So my question is, what offset can i have on a 17x9's to be as far inside the guard as possible without hitting any suspension components?
    This way i'll be able to get away with as little guard-work as possible hopefully.
    Any and all help much appreciated
    Built & Boosted.
    You can use a wheel offset calculator like the one in the link. You will need to stretch the fenders, if not cut them and add fender flares.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Which wheels are you planning to run on? You mention that you want to put more power to the ground. But did you consider the added weight of a larger wheel and tire combo will add?
      That's the Calc i always use.. But it doesn't really help my question.
      I can't actually measure my guard clearance because some of my suspension is currently not on the car.
      A few people on this forum say +20 works for them.. But others have said up to +35? I'm looking at around +25 but i can't be certain.
      More than likely, 17x9 WORK Emotion XT7's.
      So they're alot lighter than the current 17x7's i have on the car.
      With 300+ HP a few KG is easily outweighed by the traction gain imo
      Built & Boosted.
        Just measure between the plane of the hub and the knuckle. Get creative with some sheet metal and tape measure
          I had a pair of 17x9s on the back of my accord. The offset was +38, very minimal rubbing of the tire with a 225/45 and stock camber settings. No inner rubbing at all.
          DSC_2772npb by NButtz, on Flickr
          DSC_2766npb by NButtz, on Flickr
          Instagram: n_buttz
          The Jeepster ____ The CB7 ____ The TE38 ____ The S13
            Well i've looked around a bit more, ended up going with the 17x9 +25.
            So when they rock up i might just post a pic! Haha
            Built & Boosted.
