Hi all. I have a issue on the passenger side wheel. When I drive I hear a scrappin sound. I thought it was my dust shield but its not, when I apply the brakes the scrap can b heard also but not as loud as I'm driving. The steering wheel itself does not wobble or anything, can someone point me out where 2 start looking. This started after I launched hard off the line. I can drive then all of a sudden I hear scrappin noise. Then it will go away or come back louder. I was thinkin wheel bearing but its a scraping sound not that unique bearing sound.
Loud Scraping around wheel.
Mostly Usdm, some Jdm,Edm,&Puerto Rican RICETags: None
I took the brakes apart put them back together. And its not scrapin.. if it does its very very faint noise. Not as loud and scary as b4. In general I need new rotors they r super old and not smooth.
Triple checked that.
Noise came back yesterday. Took caliper apart and put it back together, and it went away. I just hear a faint noise.
Y is it when I disassemble the brakes and put it back it goes away. It has 2 b brake related. When the noise is there scrapin, and I apply brakes u can hear a different pitch.
Someone told me 2 check my hub by shakin the shit outta my rotor, and I did that. No play in it.
I don't kno where else 2 start. My rotors need to b replaced anyways, or perhaps get the whole knucke from the yard.
If it is the axle how can it be so? When I apply the brakes durin the pitch its a different scrapin sound, its only on the passenger side. Perhaps I should just get new pads
if you need new rotors might as well get new pads, and see if it takes care of the noise. if it doesn't, well at least you know it's not the rotor or pads anymore.
when you took your brakes apart, was the piston seal in good condition? if not, they may not be returning all the way and causing that side to grind (i just had this problem)
I did not see any tears in the caliper seal.
Was your scrap loud then when u applied brakes it made a different pitch?
I was thinkin those lil metal pieces also. I hhave some from a cb9 but the brakes r larger. Idk if it will fit.
Originally posted by oneoffaccord View PostWhile you are are it. Go rotor over hub. Maybe your caliper slides are sticking.
Would like to. But I don't have much help. Bleedin the abs is a puta I hear.
Slides as in the bolts? I greased them up yesterday. Today I hear faint noise. Some scraping.
Check the brake hardware for looseness. Check the wear indication to see if it's on tight. It can't be too many things that scrape under there. It could be scraping of the bad bearing. Doesn't the bearing has a dust cover? Maybe that came off. There's like an thin cover over the bearing more like a permanent stick on oil seal.
I don't understand ur last sentence. Should I remove my axle and check?
I shook rotor for movement. Doesn't move to see if my bearings are bad, I regreased the bolts that make the rotor slide.
I don't get it. If I take apart brakes and put them back the sound goes away but will come back. Caliper doesn't stick. Rotor spins freely.
