Hey guys. Im looking to get the energy suspension master kit to replace my old worn parts. For 100 bucks it seems good, and I like the red color haha. Anyway my question is, what other bushings can be replaced that the kit doesn't come with? If im doing some I might as well do it all! Thanks guys.
energy suspension
See link for all available bushings. Stoner51 is right, rear bushings are sold as separate kits. Like Domesticated, I too have most of my kit in a box because many upgrades come with their own bushings. The only ones still on the car after so many upgrades are the front lower control arm, tie rod covers and strut rod bushings.
http://www.energysuspensionparts.com...da+Accord+1990
The master Kit only contains the following:
Front end control arm bushing set:16.3110
4 - 2306 lower control arm bushing outer.
2 - 3289 lower control arm bushing center.
2 - 15.10.302.39 lower control arm sleeve.
(3/4"O.D. x 12mm I.D. x 2.040")
8 - 2280 upper control arm bushing.
4 - 15.10.244.39 upper control arm sleeve. (3/4"O.D. x 10mm I.D. x 1.577")
1 - 17152 installation instructions.
Front strut rod set:16.7103
2 - 7096 rear position.
2 - 7097 front position.
Front shock bushing set:16.8106
4 - 8096 upper shock bushing.
4 - 2295 lower shock bushing.
2 - 15.10.302.39 lower shock sleeve. (3/4"O.D. x 12mm I.D. x 2.040")
1 - 17162 installation instructions.
Front end link set:16.8105
8 - 8098 end link bushing.
2 - 15.10.200.39 sleeve. (1/2"O.D. x 3/8"I.D. x .400")
2 - 15.05.28.39 (3/8" - 16 x 3-3/4") bolt.
2 - 15.07.01.40 (3/8" - 16) locknut.
8 - 15.03.29.39 (1-1/2"O.D. x 3/8"I.D.) cup washer.
Front balljoint boot set:16.13102
2 - 13003 balljoint boot.
2 - 13005 balljoint boot.
Front tie-rod boot set:9.13103
2 - 13003 tie-rod boot.
Front spring pad set:16.6101
2 - 6133 upper spring pad.
Grease:
1 - 9.11101 grease tubs.Last edited by Tishock; 04-04-2013, 01:25 PM.
