OK hear me out, the metal in the arms should be of the same quality as say OEM or Moog yes?
If I bought a set of cheap upper arms and removed the ball joints and bushings to install my spc ball joint camber kit, would it be fine?
I'm almost done my suspension overhaul and my driver side uca castle nut keeps spinning. So I guess I would be using the cheap arm for a week until my next set of days off then would be installing the kit next Monday, Tuesday.
So to sum up is an arm an arm? Kinda like a pipe is a pipe on a short ram...
Thanks in advance
Thanks in advance
