Which camber kit?
Which camber kit?
9KIT #144.44%4KIT #255.56%5The CB9 has been reborn into a CB3
Members Ride - see my cb3 here - DOHC powah
Check out my JDM F22B swap
Watch my CB7 video
Tags: None
Good luck with those camber kits. Ingalls makes a balljoint kit too, and its supposedly a lower profile so you don't have to worry about the adjusting nut hitting the inside of the fender well as much on extreme drops... so I hear. I'm trying to find more info on all the balljoints myself, as I have the Type 1 and its not doing the trick. I'm hoping maybe a combination of the two might work out but not hit the fenderwell... we'll see.
Originally posted by KanibusI've heard that ingalls is the best..
question... does anybody know if additional alignments are required every time you rotate your tires on a suspension setup that is aftermarket?
Originally posted by DrLove'sKuDangive have both the ingalls anchorbolts and now the spc balljoint... and i prefer the spc. it could also have something to do with my suspension setups at the time, but ive never hada problem with the control arm hitting with the spc kit.
My mechanic said the same thing, from an alignment standpoint adjustable balljoint camber kits are easier to adjust and more accurate. I just keep reading these horror stories about how the locking nut on top of the balljoint will bang a hole through the fender in the engine bay. Of course I have no idea what these guys are riding on and how slammed there cars are.
I'm riding on Koni Yellows and Eibach Sportlines, so I can't imagine I'd have the same problem. I'll be ordering the Ingalls adjustable balljoints in about 2 weeks when I get paid. I need to find myself some stock anchorbolts though because I threw my old ones out when I put in my current camber kit. I'm only replacing this kit because it doesnt adjust out far enough, and I think I may have gotten the wrong one.
Originally posted by timmy0toolyou have both installed at the same time or you had one then switched to the other? i would predict that having two at the same time will definitely make the a-arms hit. i could be wrong. what was your suspension setup at the time? i bet the omnis are so stiff that they don't allow much suspension travel in the first place. i'm also looking at a different camber kit options.
now, of course, i have the omni's with spc balljoints. im lowered about 4" and the camber kit is maxed out 3°... but like you said, the omnis probably dont give enough play for it to even matter.
