need some help on how to install some coilovers just got them and i have a bunch of rubber (O) rings and do not know what the hell to do with them all. Has anyone had and prior info on this searched around but have not found any threads on how to DIY.
suspension install(bomz racing coilover)
Originally posted by rhtunersneed some help on how to install some coilovers just got them and i have a bunch of rubber (O) rings and do not know what the hell to do with them all. Has anyone had and prior info on this searched around but have not found any threads on how to DIY.
they go between the coil and the sleeve it sits on so its not metal to metal contact...
your in mass? which part of mass? got pics of ur car.... yes some of the o-rings goes between the strut and where the coil and sleeve sits at..http://www.get-gifts-for-free.com/?ref_id=4810
1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
The thick rubber ones go on the strut between the sleeve, the flat ones go between the sleeve nuts and above the top sleeve nut for the spring. I had a set of these when I first got my wagon, just a suggestion, upgrade your struts. The springs they send don't have the best spring rate and you'll blow your stock struts really quickly even if you ride with it all the way up.
