Okay, I want to know what U guyz think between getting Ground Control coilovers AND Sprint Extreme spring (F:3.25/R:3.00 drop). I currently have AGX shocks and plan on coupling them with the GC or Extreme.
GRound Control VS Sprint Extreme
I run sprint blues on my car i like em.
The sprint website or check local performance shops/warehouses. They can prob get it for you if not order it if they dont have it.
Originally posted by oneoffaccordi had the sprint blues before i had the extreme but didnt like the drop so i got the extreme ones. I love them. FUCK coil overs. small spring bouncy ride, thats my opinion. plus you are not going to get it even, you might
That said, if you're concerned with the car being low as possible on a certain spring while having damping adjustibility, I'd spring the extra $50 on Illuminas. AGX's are pretty notorious for raising the car a little bit. If adjustible damping isn't a concern, you can get away with the Extremes on stockish shocks...kmart has had that setup for a while...
Originally posted by gloryaccordyThe "size" of the spring has nothing to do with how they'll make your car ride, it's all in the spring rate...
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
Definitely, I know that the GC may be bouncier than the extreme.
To everybody else, thanks 4 Ur reply.
Originally posted by 93EXaestheticwill running sprint extremes on Kyb AGX's damage the AGX's?....i know they recommend only going down 2 inches ..i know the extremes are 3 inches..
Originally posted by gloryaccordyI don't know from personal experience but from what I've read they probably will. You should sell the AGX's and go up to Illuminas...
shit i should sell the aGx's and go with a full tein coil over system..
Originally posted by seigneur_raydenYeah, I've been leaning towards the Extreme since the begining but I wanted to hear from other persons too.
Your comparing apples to pears. You cant compare coilovers to Springs. Chances are they dont even have the same spring rate. GCs you can get any custom spring rate you want. Any spring/coilover will ride totally different with every single difference shock out there.
I guess your not racing so it doesnt matter.
Plus how can you not get it even? do you not know how to use a tape measurer? If youve done your research you will know that every 360 degree turn on the Gcs equals 1/8th.
I just got my Ground controls, 400lbs Front 425Lbs rear, waiting on my koni yellows to come in. Im racing.Last edited by phatdoughnut; 05-06-2006, 06:37 PM.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
