HYPER-FLEX SYSTEM?? Bushings??
    Hey everyone i was just wondering what do you think of HYPER-FLEX SYSTEM Master Bushing set?
    http://www.slickcar.com/productdetai...ProductID=2538
    "Energy Suspension bushings create a perfect connection between your suspension parts - resulting in perfect suspension alignment and drastically better handling. Energy Suspension polyurethane bushings eliminate sloppy handling caused by stock rubber bushings. Use Energy Suspension bushings instead of the stock rubber bushings for increased Performance, greater Durability and show quality Appearance."
    are they any good and would they make a difference? is it worth the $120 for them?
    Let me know ASAP
    Thanks
    they made my car feel 100% better. no more slope in the front end. i believe that it made my car align better with these bushings. i got no camber kit
      well shit. thats good then. cuz i got a little pop in my back. i got kyg struts with ebiach springs. but am missing a ruber back there and i seen this online and its cheap so i was like hell let me see how it is. did you buy this same one tho? like same name brand and everything. or from somewere else?
      and how much did yours cost?
      Thanks
        Thanks
        $90 on EBAY
          nice. ya i just seen them for 98 on ebay. i sent to get them thru pay pal i really how its worth it tho.
            when i take my whole car apart, ill install the bushings
              a lot of work but worth it have access to a press and have a good burner handy (not a small Home Deopt one) It tightenes up steering a lot. do it!
              The CB9 has been reborn into a CB3
              Members Ride - see my cb3 here - DOHC powah
              Check out my JDM F22B swap
              Watch my CB7 video
                "It tightenes up steering a lot" what do you mean?
                hey i found it on ebay but i was wondering is these the box that it came in?
                HYPER FLEX SYSTEM Master Bushing Set
                also... did it come with everything thats in this pix?
                Hyper Flex Pix
                  i did had to do them on my G20 to pass inspection (i didnt have to get urathane, but i did).
                  i really didnt notice a difference, at least not one worth the hassle i went through for installation (did it by hand, witha BFH)
                    Umm ok does this Set come complete for the Front and Rear also? cuz i got some Hiting on the back not the front and i ordered them and i noticed it said mainly FRONT everything. i didnt see nothing that said Rear. and i already sent for them.. is this also for the rear also??
                      It is just for the front
                      Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
                        what bushings does it change? i just changed my control arms, inner and outer tie rod ends, and the sway bar rubber spacings( which cracked within like a day ) anyways i bought new ones for the sway bar ones. anyone notice a difference for the sway bar ones for lowered cars? and what did you mean by a good burner?
                          by saying "It tightenes up steering a lot" i mean that i felt the steering to be a lot more responsive, especially when i make a quick turn.
                          Watch my CB7 video
