KONI adjustables, PITA
    Ok so i've had the koni yellows on for a while now and I love the ride but everytime I wanna adjust the dampening in the back, it becomes a freakin PITA. The clearance is so tight that I cannot fit the adjusting tool over the shock. How have others gotten around this issue without having to actually lower the shock unit?
    ...adjust accordingly
    just remove the brace and adjust then replace the brace
      What brace are u referring to?
        The ones that goes like so |/ \|. The two "/ \" can be removed. All you need is a 10mm socket or wrench to remove two 10mm bolts on the top and bottom of each brace.
        You'll have to peal back the plastic trim a bit at the top to get to the bolts on top.
        The bottom ones are a bit of a pain to get to, but once they are all out you should be all good to adjust away
        While the braces are out you could dremil out a place for the adjustment screws on the shocks.
          Sounds good and better than having to take out the shock assembly every time.
