How stiff does the accord need to be in the rear to minimize weight transfer coming off the line. If you get a "standard" eibach 2" diameter spring at any given rating would you go as heavy as possible in the rear of the car and softer up front? I know that most spring kits put a heavier spring in the front for the wieght of the engine, but what about if you reversed the kit with the softer up front? would this help with launches?
60ft times and spring rates?
Originally posted by RDR AccordHow stiff does the accord need to be in the rear to minimize weight transfer coming off the line. If you get a "standard" eibach 2" diameter spring at any given rating would you go as heavy as possible in the rear of the car and softer up front? I know that most spring kits put a heavier spring in the front for the wieght of the engine, but what about if you reversed the kit with the softer up front? would this help with launches?
Solidifying the front end with a strut bar and stiffer springs and shocks would probably help with wheel hop also.
Unfortunately, front and rear springs aren't interchangeable on the Accord. The rear springs have a bigger diameter than the fronts. Your best bet would be to hit up GC for custom sleeves, or get a full coilover kit with either very stiff springs, or switching the front and rear springs.
Good luck!
Originally posted by gloryaccordyGood question...I think having basically a solid rear end would be best for launches. Also, if you could drop the front and raise the rear to help with weight transfer and aerodynamics, you'd be in great shape.
Good luck!
A really stiff rear will compress slightly during acceleration
A really soft front will decompress GREATLY during acceleration, raising the cg. This increases load transfer.
Think about it this way, in a theoretical situation:
The front of the car weighs 1000lbs.
500lbs will transfer from the front wheels to the rear wheels.
If you had a car with 1000lb springs, the front will rise .5inches during acceleration.
If you had a car with 500lb springs, the front will rise 1 inch during acceleration.
The car with the softer front springs will transfer more load to the rear due to the increased height of the cg. Not good for a front wheel drive car.
What does this mean? don't go too soft on the front spring rates.
As for shock settings, a stiffer rebound shock setting will increase the RATE of load transfer. Set the front rebound to the softest possible to keep the load on the front tires.
IMO, I don't see how really high rear spring rates will keep the front of the car down. The same amount of load transfer will happen, but the rear will just not compress as much. Allignment will be affected.
<---must be tired...just went against all schools of thought lolFor Sale:
itr mid pipe = $80 + shiping
tr injen sri $80 + shipping
(2) Eibach ERS 600x2.5x600 = $80shipped in US
