axle problems
    axle problems
    I was putting on my new struts and springs and camber kit and one side went fine. When I went to put on the other side the axle slid out, like with the little bearings on the studs on the axle. there's three of them on the tranny side. So how do I put it back in?
    91 accord lx, ebay intake, koni rsk kit, 17's, clear corners, red clear tails, and a type r lip when I'm not in Pullman
    ya the shaft pulled apart, I'm goin to pull the whole axle out tomorrow and put it together on the ground. It'll be practice for when the axle does go, and the local parts store owner's kid was helpin me and he said they didn't have an axle in stock any way. So I'll get it put together, get some practice, and next time I"ll know what I'm doin. It was the drivers side that came apart too. Passenger side went together fine. Boy I'm learnin alot about hondas fast.
      nope, boot didn't tear, I took the zip tie off to see why it wouldn't slide back together. There really isn't much dirt. I was doing it on cement, and what did fall I cleaned up pretty good. So what's the trick to getting it to slide back together?
        each of the little nuckles on the shaft have to be slid just a hair off the shaft and the squar piece on the nuckles need to have the flush sides all kinda facing toward each other in order for it all to slide in. Only took me probably 3 hours to figure that out, but it all went back together.
