Clik Clik Clik as I turn.........
    Hey....my car goes clik clik clik when i turn the wheel.....do I need wd-40..hehe...I dont know, I think it might suspension right? Its annoying....and kinda embarassing considering everything else runs smoothly..hehe.."touch wood" ..
    one of your cv joints. theres a diy,look it up.
      this should help,good luck.
      http://www.fourthgenhatch.com/axle.html
        Thanks man.....
          check ur lower ball joints.....
          Finally Up and Running. Numbers to Follow. Check my MR
            no prob man.
              no it is the cv joints axles, mine were bad when i got the car the got worse, eventually they clicked bad when i drove straight and grinded like a pencil sharpener when i turned. pretty simple fix the hardest part was breaking the nut loose on the bottom of the wishbone
                I think he needs help with his car.
                  Just replaced both mine..
                  shiit was squirting grease all over my wheels.
                  by the way slate.. your at offut? just noticed im at mcchord in Wa.
                    Air Force powa.
