Ok folks ive decided to call on the cb7tuners for this one.
1. I have a major squeak on the pass side front.
2. It squeaks on up and down moation's and sometime's when turning the steering wheel.
2. I have took the suspension apart a few times now and still can not locate the problem.
3. It's not the wheel rubbing on anything. It's not the dust shield. Axle is pretty new and no torn boot's on the axle.
4. I have already replaced the upper control arm and still didnt fix it.
5.Upper control arm is ingalls ball joint kit, no torn boot and ball joint still feels good and tight and no squeaks from manualy moving it.
6. It sometimes stops making noise after i jack the car up and look at everything, might last a few day's before the noise comes back.
7. Sway bar end links are new es red's very very well lubed, looks nasty with so much grease on it to be honest.
8. Tested the ball joint by pushing and pulling the top and bottom of the tire while jacked up and there is no play ball joints seem ok, also no play when i push and pull left to right tie rod seems fine.
9. Springs are eibach sportlines and this weekend will have new tokico shocks but it does not sound to be coming from there either.
10. Alot of tq steer (KIND OF) meaning i can take my hands off the wheel and hit the gas and the steering wheel will move left quite a bit but the car stays pretty straight.
So I've given all the info i can think of with this problem. I've checked everything I can think of so your idea would be very welcome here. If I can not find the problem by this weekend when i get the shocks on im going to get a new ES bushing kit and swap all them damn things out too. Thanks !
my shit should feel really good after that. Oh well thats another $100 down the drain.. Im really thinking its time to upgrade soon.
