I have decied to upgrade my supension set up with some Neuspeed Race Springs. The thing is they will be on Tokico Blues for right now? Does anyone know how the ride quality will be, will it mess up anything. The shock set up will only be temporary until I can get some Koni Yellows. Thanks
Neuspeed
Did you have any trouble with your tires rubbung against the fender? And does your control arm hit the inner fender walls at all. ThanksOriginally posted by PRIMOCB7
i was on neuspeed race springs w/ tokicos for almost 3 years..and i rolled on 18's. but i'd recommend a camber kit coz the tires will wear out really fast w/ a drop that low.
Re: Neuspeed
never had that problem..and i always used 215/40/18's. if you ever plan on dropping a car, especially at 2in. or more, you gotta invest in performance shocks/struts, camber kits, and when you buy rims, make sure the offset is made for hondas(+40...+44)Originally posted by accordex_1990
it helps so that the rims don't stick too far out the fender, or too far in.5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
Re: Re: Neuspeed
Thanks for the feedback. For now I will use the tokico blues but in two months will uprgrade to some Koni Yellows. The drop will be on my stock wheels and tires, but I will still get a camber kit. Just wanted to make sure the wheels wouldn't rub or the control bar would hit against the fender wall. Its just that I was reading some other posts in Suspension and alot of people were having that problem. Could it be that they are using bigger rims and wider tires. Thanks againOriginally posted by PRIMOCB7
Definately an excellent spring choice. Good luck with the tokico combo. Let us know how the ride is in the "rate your suspension" thread. May I suggest the Neu. Koni Yellows when you get your Konis. This combo is by far my best combo yet. I LOVE the ride with them. I had a problem with the control arm hitting the inner fender wall with all my other suspension combos but not this one."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
What size tires did you have when your control arm was hitting the inside fender. Do you think I would have that problem if I use my stock rims and tires. ThanksOriginally posted by h23accord
I'm running neuspeed race and AGX's and I haven't had a problem with my control arms hitting. Good luck with the new setup.Originally posted by accordex_1990
What size tires did you have when your control arm was hitting the inside fender. Do you think I would have that problem if I use my stock rims and tires. ThanksHonda-Tech Username: Lostcb7
The cb7tuner.com OG.
I was running the stock set up with all my suspension setups. The Neu. race and Koni Neu. Yellows have given me no problems whatsoever and I clear speed bumps no problem and it handles great and the ride is great! I am currently riding on stock wheels with Yokohama AS 430 195-60-R15. 2 finger wheel gap all around gives aggressive rake up front."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
i may buy nuespeed springs too got a good deal on them just wanted to knw also would the control arm hit with 18's i am going to go with the neuspeeds and gr-2 struts with 215-35-18 tires what do u guys think of that
not tryin to steal ur thread just didnt wanna make up another askin the same Q's
They will void the warranty yes, but everybody I know who runs them has no problems w/ them on AGX's. I def. think the yellows would be more comftorable thoughOriginally posted by JailBa8
I woulg save up a bit and go with koni yellow or the neuspeed koni. I think neuspeed race r a lil too low for agxs
