what else?
    what else?
    for a while now i had a bad vibration when i braked. eventhough i changed my rotors the vibration persisted but it wasn't as bad as before. i did my usual check up for a bad ball joint and a bad wheel bearing but everything was tight and no movement.
    well when i changed my axle a few days ago and i had to remove the wheel assemby i rechecked it again and i found out i need a new wheel bearing. but after i did put everything back i started hearing a squicking sound.. can you say ball join. anyways so i need to replace the wheel bearing and ball join.
    my questions are... since i am removing everything and i am taking the wheel assambly to the shop to change my ball join and wheel bearing what else can i replace since everything is out?
    ps i am buying all my parts from auto zone since their parts are decent and not very expensive.
    poly bushings, aftermarket sway bar, the list goes on and on and on and on....the car is ~15 years old, im sure it could use a lot of things you wouldnt think it would need.
    JDMRIDES.ca
      done all of the above. but i don't want to put an aftermarket sway bar inthe front. and i already have the progressiv one int he back.
      just want someone to refresh my memory on what to do while both wheel assambly are out.
