Toe arm Bolt Stuck
    Toe arm Bolt Stuck
    Im replacing my rear toe arm with megan racing ones but the bolt is stuck. I guess this is the bolt that is actualy used to do adjustments. I got the nut off the bolt but the bolt wont budge.
    I can move the bolt around but it seems like its locked into the other side. im washing it with PB blaster every 10 mins but its not moving. Any Ideas anyone?
    I cant Slam further. The ground refuses to get any lower.
    same thing happened to me. i had to hacksaw in between the control arm and rear crossmember bracket and knock either end off :\
      did it happen on both sides?
      Neone with another idea or same problem?
        Both sides where froze in. It was the bushing that was cezed onto the bolt and it happend on both sides I show I solution pretty soon, I just gotta take pics.
          yep, happened to both sides to me too.
          its not a normal bolt with those line/slits along the side of the bolt, its thicker and solid and comes flush with the shape of the bushing... so its the first to go
          good job on getting them out, at least u didnt need to save the control arms
            Lol, yeh they might as well have been one soild peice conected to the Bolt. here was my solution
            We just took a oxy-sedalene torch to it, ground and then repainted the crossmember lol.
            SO if anyone else is doing rear toe adjust and there adjuster is rusted or ceazed. Here was my steps.
            Remove long bolt holding lower control arms (single long bolt). Remove rear cross member (4 bolts). Cut out upper bushing/bolt on cross member (dealers choice on how to do this). and reassymble.
            A side note. It looks like these megan toe adjust control arm just bearly gets to 0 degrees( if that) might even be alittle positive so if your planning on going for a toe in this might not be the part unless your modify the cross member alittle.
            Good luck
            And Thnx 2 Mike
              installed pics of the megan stuff?
              -1992 Accord EX H22 234whp 185wtq
              -1993 Accord EX SOLD
              -1995 Accord EX Wagon Daily Driver
              -2012 GMC Canyon V8 4x4
                  Sweet! Looks good...
                  Sold, but not forgotten.
                    Would both arms allow you to get a wider range of adjustability? because i know that it seemed odd that both front and rear lower bars come adjustable.
                    Engines hate me... thats why they commit suicide
                      I dont know, The rear rear lower control does not (stock) have any adjustments on it. I assume that if you go with the pair from megan it could be a wider adjustment but realy, when racing there isnt much reason to go toe in. Its got a huge toe out adjustablility... If both where pushed out all you would do is widen the rear end and cause rubbing. Just wouldnt do much I supose.
                        what type of shocks are those?
                        1993 Accord LX - Sold
                        93 BMW 525it - SOLD
                        92 Accord EX Sedan - SOLD
                        2000 Accord Coupe - Traded-In
                        2003 Accord V6 6spd Coupe - Sold
                        2001 Honda Civic Ex - SOLD
                        2013 Chevy Traverse LTZ - Kid hauler
                        2003 Acura Tl 3.2 - Daily Commuter
                          They are Kby- gr2 i think, basicly a stock replacement. Its a strut actualy right? The springs are Neuspeed Sport.
