Hey everyone, so I was playing with my tire pressure lately (OEM 15" six-spoke wheels, 195/60 Yokohama Avid H4S tires), and I ended up going with 37psi front, and 35psi rear. Turn-in is noticeably sharper than using 32 front, but the ride is harsher too (I've gotten used to that, but I may cut back to 36f/34r). My experimentation here started from reading an article (I wanna say it was in Sport Compact or Motor Trend...yeah, how'd I get those mixed up?) where they mentioned that manufacturer's recommended psi ratings are more for ride comfort, and decent tires should be able to handle more than that. So anyway, what pressure is everyone else running? It'd be cool if you mention what wheels and tires you're running too. Thanks!
What tire pressure do you use?
205/40/17 32 front and rear
Originally posted by Granite CB7I have 205/50/15 Kumho Ecsta SPT's and I run 51 psi all around, max is 51. All my strut mount bushings are very worn from my D2's, which I'm redoing all the bushings front and rear. Then I can really dial tire pressures in and do more suspension adjustments too.Is that cold or hot? You do know that when the tires warm up, the pressure goes up to 2psi higher, right? But even then, that's still pretty high bro, I'd be scared!!
Anyways, manufacturers usually recommend 32psi all around...But according to the pros I talked to at an autocross event, 42psi is usually the optimal pressure..with 32psi, your tires will wear out faster (apparently)..
Summer time, I usually run 40psi up front, and 30psi in the rear...When they warm up they go up to 42psi and 32psi, respectively..The reason I do this is so that the front will have more traction than the rear..You can actually feel it, understeer is greatly reduced around corners, and I can also launch better..
Winter time, I usually run 34psi all around..Gives the car a more neutral handling, especially in icy/snowy conditions
Ronald
well i use 40psi rear and 35 30 in the front but on some tires like the parada spec'2 i found out they give more overstear with more psi in thefront vs the rear you just have to keep checking if you are real into getting the most out of your set up. some people will tell you it doesnt matter but i can tell a diffrence. keep checking your suppost to everytime you fill the gas up any ways
I usually try to stick to the recommended 32-35psi
I imagine it might be a little better to run the front a bit higher than the rear.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Originally posted by Ronald_Type-RWoah you actually run 51psi?!Is that cold or hot? You do know that when the tires warm up, the pressure goes up to 2psi higher, right? But even then, that's still pretty high bro, I'd be scared!!
