what is the bore size of the rear disc brake master cylinder?
    im gonna do a disc brake swap and i found the brake master cylinder online and it gives the exact bore size at 0.938 in. It also lists that it fits all sub models accord, but since the master cylinders aren't the same, i was wondering what the bore size should be. It says it will give increased performance, so im guessing its the biggest bore size offered?
    http://store.summitracing.com/partde...33+4294839072+
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    I believe the BMC for rear discs are the same as those equipped with ABS. In that case, bore size would be 1 inch, and one of the two fittings would be bigger than the other..
    Hope that helps! 0.938" is stock I believe, 15/16"..If you want an upgrade, then look for the 1" BMC
    Ronald
    |~~~~~~~~~~~~- Project CL1 Euro-R continues -~~~~~~~~~~~~~~|
