i grabbed a set of calipers off a bb4 prelude to test fit them on my accord knuckles w/ 11" wagon rotors. The only problem is the brackets have clearance issues, they basically bind on the wagon rotors. Are the accord wagon brackets different then the bb4 brackets? anyone experience this problem. any insight is greatly appreciated..
BB4 Caliper Question
Header Whorage and Official Part out sale.
Official Garage Sale Thread
http://jdmconcepts.com/ Head porting specialist..Tags: None
where do they bind?
id imagine they should be fine since the rotors are the same size as the prelude vtec ones. what stamp is on the brackets you have?
basically if i bolt them up they bind on the outside face of the rotor preventing it to spin. I can post the stamp on the brackets tomorrow.Originally posted by cp[mike] View Postwhere do they bind?
btw hope you have merry christmas mike
I think the rotors might be of different thicknesses. Try cross referencing the part numbers on majestic for BB4 VTEC rotors and Accord Wagon rotors. Do the calipers too and see if they're the same. I think the calipers are identical, just not sure on the rotors.
I'm using all Acura Vigor brake parts and it everything bolted up fine to my knuckles
What a noob...learn to search!Originally posted by bmxicansd View Posti grabbed a set of calipers off a bb4 prelude to test fit them on my accord knuckles w/ 11" wagon rotors. The only problem is the brackets have clearance issues, they basically bind on the wagon rotors. Are the accord wagon brackets different then the bb4 brackets? anyone experience this problem. any insight is greatly appreciated..
jk craig
If I remember correctly the BB4 should be running a 23t bracket. The wagons and 5th gen AV6 run a 25t bracket. Basically you need to find a 25t bracket to work with the wagon rotors or use vigor rotors to work with your 23t brackets.
You need the 23t bracketsOriginally posted by Blk EX Coupe View PostWhat a noob...learn to search!
jk craig
750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
Yes i just confirmed and yes they are the 23T brackets.Originally posted by mndude07 View PostYou might have 23T brackets. I think you need to use the 25T. I could be wrong about that though.
Thanks Losi..Originally posted by Losiracer2 View PostI think the rotors might be of different thicknesses. Try cross referencing the part numbers on majestic for BB4 VTEC rotors and Accord Wagon rotors. Do the calipers too and see if they're the same. I think the calipers are identical, just not sure on the rotors.
I searched but didnt find the information on the site. thanks again..Originally posted by xkjnboix View Posti think u pulled si calipers rather than vtec calipers. if they say 17cl14vn then they are si's and yes u need the vtec bracket too. all this info is in the brakes forum. do some reading its all there.
haha.. Thanks Long.. btw, I finally installed the front st sway bar, but then i run into this problem.. at this rate my car will never be done haha..Originally posted by Blk EX Coupe View PostWhat a noob...learn to search!
jk craig
[QUOTE=Supergenius;2357670]You need the 23t brackets
QUOTE]
I have the 23t brackets..Header Whorage and Official Part out sale.
haha sounds about right..Originally posted by Blk EX Coupe View PostI sold my cb almost 2 years ago, so you bought those from me like 2.5-3 years ago.....
I barely drive my cb anymore yet alone have time to work on it. haha i did however replace the sway bar bushings
i got the 17cl15vn calipers with 23t brackets.
haha
how about do a rotor over hub...and call it a day..take hubs out of the prelude knuckle and grind the out race down to fit our bearing...the caliper will fit onto the knuckle with no problems after check my sig...New paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Motivation is one of the keys to life....tell me "can't" and I wll show you I can
