**The Problem**
I have a 91 EX wagon. i want to run a set of 14x7 wheels. (dont tell me i cant. this is what i want. if you dont have anything constructive to add dont post. thanks.)
**The Plan**
Ditch the Wagon Knuckles/calipers for some ROH swapped sedan/coupe knuckles/calipers
**The Facts**
The wagon has 11.1 rotors.
The wagon has larger calipers.
The wagon uses single piston calipers.
The ROH swap also uses 11.1 rotors.
The sedan/coupe calipers are also single piston.
The pads are slightly smaller.
**Questions/Concerns**
-If i use this ROH setup would it still be safe on a wagon?
With a sedan/coupe. ROH is like a brake upgrade and wagon knuckles/calipers are also an upgrade. so if im putting the ROH setup inplace of the wagon stuff wouldnt that pretty much break even so to speak?
-Could i counter the smaller brake pads with better pads such as EBC or something like that? would it even make a difference?
-For the most part the wagon will be used as a dd to get me about 15 miles back and forth to school. and if i get a second job at a pizza shop doing delivery. but 90% of my driving will be speeds less then 50mph and around town. also. my wagon is 5 speed and i use the transmission to slow me down so im not heavy on the brakes to begin with.
-Would this still be considered a safe brake setup if i wanted to go on a road trip? i live in pa and have family in Indiana. id rather take the wagon out there then my girls Saturn but if its not safe then i wouldnt even consider it.
Any thoughts/imput is much appreciated.
**The Plan**
**The Facts**
