I searched h-t archives for an answer, but no luck. I found a 94 EX sedan with discs in the rear I can pillage, but I am not 100% sure they will fit my 1991 Wagon. Can anyone help me find the answer to this one?
Thanks
1991 Accord LX 'G Wagon'
2001 Tafetta White Integra GSR Sedan
Originally posted by fizzbob7 most of the same part numbers check out....i'd check to make sure it wouldn't make the wheel stick out or in and wouldn't sit too low or high for any reason.....but since you're swapping from rear drum to rear disc, you might run into problems with the hub for some reason, but i don't really see why...i've never tried it personally, but it should be do-able.....just get a tape measure and check all that you can as far as where it sits in relation to the rest of the suspension.......unless someone tells you that it wouldn't work and they're 100% sure, then i'd go for it
i agree with fizzbob.
question, are you running stock 14" wheels, or a larger aftermarket wheel? i would see possible clearance problems with the stock 14". my thinking is that the 94 ex wheel is 15". i may be totally off in my thinking though. i wouldn't see any problem with a 15" or larger aftermarket wheel though.
