I read the article that somone on this site tried to go a cheap route and had accord hubs that were not the same and the only acura dealership around(6 hr drive) tells me that its the same part number for both hubs I wish i could just give them a part number and theyd be able to distinguish the diffrence by that but wtf is going on I have heard otehr ppls posts pertaining to this topic I need my hubs asap
CL hubs and 98-00 accord hubs why does the acura dealer say there the same thing?
http://www.accordinglydone.com/forum...ight=rotor+hub
thats the writeup I used on my 5th gen when I did it a year and a half-ish ago.
The part number for the CL hubs you want is 44600-SY8-A00.
just order 44600-SY8-A00 from the acura dealer and youll get the right thing, dont try to compare them to accord hubs (Honda, which the acura dealer wont have) which are definitely different.
edit: mark beat me to it. you can always order them online http://www.acuraoemparts.com/delray/jsp/home.jsp
Originally posted by CB7EX-RI read the article that somone on this site tried to go a cheap route and had accord hubs that were not the same and the only acura dealership around(6 hr drive) tells me that its the same part number for both hubs I wish i could just give them a part number and theyd be able to distinguish the diffrence by that but wtf is going on I have heard otehr ppls posts pertaining to this topic I need my hubs asap
Originally posted by owequititThey are different. I have a set of 1998-2008 Accord 4 cylinder hubs sitting in my garage and they DO NOT work.
yea I read a few times on here that they wont work as well as on accordinglydone , so your saying I should "take the plunge" and just order the hubs with that number from the acura dealership.......I have a garage for a whole week comeing up this week that I usually just do my bodywork in but the truck im working on the guy has went away without giving me any $ for supplies so im gonna throw his truck out and bring in my 92 sedan and I plan on doing this......I already have the hubs and pads im considering new calipers as with a trade in I can get them pretty cheap, new lower ball joints and hubs and you guys can confirm this and I thank all of you for your response I need accord wheel bearings pressed into my cl hubs when they arive rite? this is what i gather from my reading my father runs a machine shop so I have access to there 2 hydraulic presses. Will the 4 bolts I get with the accord bearings bolt rite into the CL hub and do the holes need to be alinged on compression? im asuming they do but Im pretty sure the bearing casing would just spin untill they lined up for me after being pressed in. Thanks for any help guys,
also one quick note quick note I have CL rotors.....but for the 4cy...with these I can retain stock calipers and pads rite? are these 10.2" diameter and the 3.0L would be the 11.1"?Last edited by CB7EX-R; 04-24-2007, 02:40 PM.
I honestly dont remember if they went in that easy. they probably didnt. I sorta recall having to use my uncle's hydraulic press, but Im not sure if that was to separate the knuckle from the old hub/bearing or to press the new hub into the new bearing, or both.
I do know, however, that I used the mallet method to get the new hub/bearing into the knuckle.
