What are the most aggressive wheel and tire package do you have on your cb or that you have seen? I'm going for a 17x7.5 Rota wheel. I know there will be fender work involved and I'm okay with that. Just seeing what you guys are running.
Aggressive Wheels
Originally posted by ss93cb7 View PostWhat are the most aggressive wheel and tire package do you have on your cb or that you have seen? I'm going for a 17x7.5 Rota wheel. I know there will be fender work involved and I'm okay with that. Just seeing what you guys are running.
there are guys that rock 20's on the fourm
Originally posted by ss93cb7 View PostI don't want to go too large I am thinking of running 17x7.5 with a 25 offset unless i feel the need to go larger.
Just to give you an idea of how large you can go..My new shoes are 17x9" +42 all around..For the rear I need 3mm spacers so the wheels will clear the trailing arms..For the fronts I will most likely be running 8mm spacers, pushing the front wheels to +34..I will be running 225/45/17 all around..A little stretched, but not enough to clear fenders..
Having said that, after all is said and done, the rears will sit 2-3cm out of the fenders. The fronts will most likely be the same with the 8mm spacers..
To give you an idea of how much 2cm is..(Not my car)
It gets worse from there..So the point is, if you want to go with larger a.k.a. wider wheels, just watch for the offset..The wider the wheels, the higher offset you must go with. Stretched tires and negative camber do help, but they can only do so much! In the end, it's function vs. form, and i'm definitely going with function this time.
Good luck with your project! And do plenty of research before making a final decision.
Ronald
best thing you can do is go to a tire ship and try on some different sizes.DEVOTE
FS: Lokuputha's Stuff
Originally posted by Ronald_Type-R View PostTimmy0tool ran 16x8" with +26 offset before and they cleared, so 17x7.5" +25 is definitely not large. Just normal-sized wheels with low offset.
Ronald
I have 16x7 +40 on my car now and it's *just* inside the fender in the rear. I think for a decently lowered CB, ideal wheel size is 16 or 17x7 with a +30 offset. That's the size I would wanna rock with
Originally posted by gloryaccordy View PostI have 16x7 +40 on my car now and it's *just* inside the fender in the rear. I think for a decently lowered CB, ideal wheel size is 16 or 17x7 with a +30 offset. That's the size I would wanna rock with
Ronald
"The Turtle"
DD/Trail Rig/Mud Bug
