Eibach pro spacers
    Eibach pro spacers
    Do i have to get extended lug studs when i install eibach pro spacers for the rims?
    it depends on the width of the spacer. if you go larger than 10mm then i would get extended lug studs.
    1cor10:31
    - 92 LX coupe
    - 96 EX wagon (sold)
      i'd say if you go larger than a 5mm spacer to get extended lug studs, lol.
      under 5mm, you're safe. between 5 and 10 mm is personal preference. above 10mm you'll definitely need them.
        wow you guys need spacers?
          some need them (timmy0tool)
          some just want them (me)
            Most of the Eibach spacers have another set of lugs set in the spacers, so you shouldn't need extended lugs for that kind.
            -Jay
