Alright so i have been searching for about three hours and this is what i came up with just want to make sure im correct so can people shed some light on this situation for me thanks.. Here's the scenario.. ok My buddy has a 93 accord LX auto.. i have been helping him swap in his OBD-II H22 so here goes..
I found that if i bypass the resistor box on the injectors i can still use the OBD-II injectors and cut the connector and splice all 5 wires together to bypass the box..
Next get the 4 injector connectors and splice them into the F22 wire harness in place of the OBD-1 connectors??..
Next keep the OBD-I fuel rail from the original F22 so the fuel line fitting is on the correct side?? now next i have to swap out the existing OBD-II H22 distributor for an OBD-I distributor, Now im guessing the original wont fit so im guessing a distributor from say a 93 or 94 Prelude H22 would work correct?? Im guessing that motor is an OBD-I, please correct me if im wrong.. as for the ECU connectors inside the car they will still be OBD-I so keep an OBD-I ECU..
the rest of the harness should bolt up correct??.. As for that im laking some information as to what else is needed to correctly engage V-TEC, Like what wires and such..
Now the Tranny is a LSD Auto so are there any wires to add to that one too?? Thank you and please help me out guys we would like to get this done.. We hate seeing another CB7 broke down in the garage..
Thanks
Thanks
