h22 problems
    h22 problems
    fuel pump running constanly when you turn ignition , lots of gas l in the cylinders , resister box warm, ecu check light on solid . what could have started this problem ?? guyz
    '' we racing or you just blowing smoke ?''
    Hmm...check engine light on...
    what to do...
    what to do......
    To-Do List for Today
    Be Awesome
      what was your engine again? OBD1 or 2?
      93 Accord LX Sedan (sold)
        its obd2 - 0db1 conversion
        im having idle issues ,the car starts nice ,smooth and ya know normal . after a test run it behaves irratic, shaking until you hear clunking noises like its about to die . has anyone got the dizzy wiring sequence ? ive muddled all the plug wires up ..after swapping
          I think its...
          34
          12
          front-->
            thankz nitewolf
              no problem
              btw try (after you put them on) taking a clear pic of where each wire goes on the dizzy. it will help you out in the future
                what could be the cause ?
                when the engine starts from cold the idle fluctuates slightly im using a h22a5 obd2 map sensor ps30 shouldnt i be using a ps31 map sensor in this case if ive converted to obd1 ? cos im thinking this could be the cause ive changed & cleaned the iacv and the fiv throughly any more thoughts on this guyz ???.
