auto to man question
    im currrently doing this swap and im wondering if i could just take the wiring from the car that im pulling the whole set up from and use it in my car or would it just be easier wiring it myself using the swap guide?
    manual hondas have some different plugs than the autos. dont know why. but i found that the hard way.
    miss my turbo cb7
      If your trying to say you wanna use H23 wiring harness on your car then that won't work. The H23 is OBD2 and your car is OBD1. You can convert the motor to OBD1 and use your harness but your gonna have the pin the ecu plugs for the extra sensors.
      -1991 Honda Accord LX H22a-
        becuase the main plugs are different, you would have to swap EVERYTHING which would require removing TONS of stuff including the entire dashboard and most of the stuff behind it, including the heater core.
        just modify it following the directions and cut off the extra plugs.
          no im not converting to the engines harness....i know it obd2 im going from car to car. a 93 auto and a 91 manual. they are both all part dash board and everything. except the 91 still have the engine in it. i just didnt know if it would be easier to jsut take the wiring from the 91 and put it in my 93 for the 5 spd swap.
