What do I need to finish this swap?
    Also, I heard you cant keep the power steering?
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
      Originally posted by f22-dohc
      that the thing.. some mechanics dont know how honda's are legos.. everything bolts in
      Dude Thats awsome! Im gonna add that to my sig!!!
        You can. You might have to braze the lines together, but its nothing that any experencied shop cant handle.
          Ok so I need a P14 ECU, I need to install a knock sensor and braze together the power steering lines... What else?
            you don't need to braze it,use ur existing accord brackets (alt & p/s) thats wha i used kept oe hose and p/s pump.
            do you have an auto or manual?i an auto i've got a spare p14 ecu.the belts u'll need will be for your accord,not a prelude.
            also the a/c compressor will bolt to it w/ no problems.
              Its a manual, do I need to have a p14 ECU? And I need to install the knock sensor myself? I dont want to mess up the engine by drilling holes in it, is it safe?
                p14 yes if you want the full potential of the motor,but you can use ur fact. ecu.
                as far as knock sensor goes,i think myself and phatdoughnut are the only ones running this set up.he mountes his where his p/s should have gone,drilled and tapped to fit.
                i kept my p/s and put it mine,in head.theres a mounting tab under dizzy,i drilled out,tapped.after i put it in i clsed off the opening w/ some quicksteel.
                i've also heard of people using a nut and j.b welding to the block.
                i don;t trust jb weld,so i don't recomend it.
                rule #1 in swaps,take ur time!!!
                and do it right the 1st time.
                  That sounds kinda complicated, for me at least... What about an F20A swap? Is that easier?
                    why don't u just swap over a H22..at least that way, you can read, have, and follow every single detail of instructions thats already been written for you..okay?
                    here's the link...again:
                    http://www.cb7tuner.com/vbb/showthre...&threadid=5423
                    5.6L V8 32V DOHC
                    JDM HERITAGE - US BUILT
                      Guys! Read his post again. He wants to swap an F22b1 from a 5th gen!!!!!
                        we know, but at the same time, he wants to swap in a F20a, and then on another post, its to turbo a F22ax, and then its.......eh, whateva. good luck with your swap(s)
                        5.6L V8 32V DOHC
                          LOL sorry, im pretty sure im getting the F20A now... I just need some info on that and im done =)
