Hey guys bad news in DIZZLES WORLD my t-belt snapped the other morning, thats why i had no spark i tryed the coil, dizzy all that stuff then i had someone tow it to the shop and they told me my t-belt broken. didnt bend any valves tho! lucky me.. so i should have it out the shop this week. hope i can make the meet
Timing Belt Snapped
How does a snapped timing belt keep you from getting spark? Also like stated above; did you(or the shop) do a compression check to see if the valves are still sealing properly? Anyways good luck and hopefully you've have it back running soon.
JayHittin Switches - Draggin XhaustAlways Under Construction
Originally posted by MDIZZLE4SHIZZLE
i bent some valves in the #1 cylinder so h22 here i come!!!!1
But if your going H22 then this is a good thing, I guess.
Good luck.
Originally posted by akkordlayinkit
No way man, that sucks, sorry to hear...I had my timing advanced 40 degrees and I didnt bend any valves...is it your exhaust or intake valves? And why not just new valves? Surely it didnt crack the piston, right?
Good luck.
JayTHIS ONE HERE IS CRACK!!
