Ok, so is it true that the P28 ecu won't look for the Knock and IAB sensor?? a prelude guy told me that, the JDM H22A engine will run fine without it if i'm running a p28 chipped w/ h22a base map, is it true?? Will lose power if I didn't hook up the IAB sensor for the butterfly??
Life would be much easier if I didn't have to add those two wires to the ecu.
All helps are much appreciated!
Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
